中文讨论区
Not able to associate USERS to wireless user on WIFI
Feb 17 04:42:52 station-down * b0:c0:90:c0:f3:3b 40:e3:d6:43:ad:12 - -
Feb 17 04:42:55 mac-auth-req -> b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - -
Feb 17 04:42:55 mac-auth-success <- b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - -
Feb 17 04:42:55 assg-vlan-req * b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 1 174 new vlan: from mac auth for wireless
Feb 17 04:42:55 assg-vlan-resp * b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - 174
Feb 17 04:42:55 station-up * b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - - wpa2 psk aes
Feb 17 04:42:55 wpa2-key1 <- b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - 117
Feb 17 04:42:55 wpa2-key2 -> b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - 117 mic failure
Feb 17 04:42:56 wpa2-key1 <- b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - 117
Feb 17 04:42:56 wpa2-key2 -> b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - 117 mic failure
Feb 17 04:42:57 wpa2-key1 <- b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - 117
Feb 17 04:42:57 wpa2-key2 -> b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - 117 mic failure
Feb 17 04:42:58 wpa2-key1 <- b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - 117
Feb 17 04:42:58 wpa2-key2 -> b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - 117 mic failure
Feb 17 04:42:59 wpa2-key1 <- b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - 117
Feb 17 04:42:59 station-down * b0:c0:90:c0:f3:3b 40:e3:d6:43:ac:32 - -
Feb 17 04:43:15 mac-auth-req -> b0:c0:90:c0:f3:3b 40:e3:d6:43:ad:12 - -
Feb 17 04:43:15 mac-auth-success <- b0:c0:90:c0:f3:3b 40:e3:d6:43:ad:12 - -
Feb 17 04:43:15 assg-vlan-req * b0:c0:90:c0:f3:3b 40:e3:d6:43:ad:12 1 174 new vlan: from mac auth for wireless
Feb 17 04:43:15 assg-vlan-resp * b0:c0:90:c0:f3:3b 40:e3:d6:43:ad:12 - 174
Feb 17 04:43:15 station-up * b0:c0:90:c0:f3:3b 40:e3:d6:43:ad:12 - - wpa2 psk aes
Feb 17 04:43:15 wpa2-key1 <- b0:c0:90:c0:f3:3b 40:e3:d6:43:ad:12 - 117
Feb 17 04:43:15 wpa2-key2 -> b0:c0:90:c0:f3:3b 40:e3:d6:43:ad:12 - 117
Feb 17 04:43:15 wpa2-key3 <- b0:c0:90:c0:f3:3b 40:e3:d6:43:ad:12 - 151
Feb 17 04:43:15 wpa2-key4 -> b0:c0:90:c0:f3:3b 40:e3:d6:43:ad:12 - 95
Re: Not able to associate USERS to wireless user on WIFI
Is this a single device, or you cannot associate any devices?
This looks like a WPA2-PSK SSID with mac authentication.
Has this ever worked?
Do you have the right preshared key for your devices?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks for the quick response.
Problem was there with Preshared key.
and i believe we can make out from logs also.
