中文讨论区
problem of mobility
Could you tell me how to set up two layer roaming for Aruba wireless controller? Ensure that the signal can be seamlessly switched. Now the situation is that when roaming, only the signal can not be received before switching to another AP
Re: problem of mobility
Are you trying to roam between two access points on the same controller?
