07-19-13 Expert Day
Frequent Contributor I
Quick Connect for Android and onboarding for Clearpass
Hello.
Is there any plan to make the quick connect app for android available for download from the clearpass server itself since mutliple vendors don't have the ability to create a pre auth access restriction allowing android.clients.google.com as for example in cisco you can make pre auth ACL with IPs not domain names.
Re: Quick Connect for Android and onboarding for Clearpass
Islam Soliman wrote:
Hello.
I don't know if there are any plans, but to install any android app from a local web server the person would have to configure "allow install from non-market sources" in their android phone which would be a very bad user-facing experience....
