802.11 Client Device Interoperability
IAP-93 is unstable with mac book air
I am a newbie of Aruba network.
Our school have built a wireless network with 15 IAP-93. All the AP is controlled by the virtual controller. We have encountered two problem for this network.:(
1. Some clients (e.g. Computer with Level one 0301USB) cannot obtain the IP from our DHCP server intermittently. Other clients can obtain the IP every time. "DHCP request timed out" alerts found occasionlly in th web UI. I would like to ask that anything can be done the improve the performance.
2. The connection between AP and Mac book air is unstable. The connection is on and off frequently.
Thanks a lot.
Re: IAP-93 is unstable with mac book air
It it possible that you have alot of interference in the Area?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks for your advise.
How to check it? Any method can be used to get rid of interference or noise?
How many clients do you have on The whole IAP system (type show clients)?. To check interference, type "show aps"
Around 30 clients at a time.
The noise level seems to be OK but the utilization is little bit high sometime.
Please note that some APs located in the same position but in diffiernet floors. Does it affect each other and make the service degrade?
