802.11 Client Device Interoperability
Issues between MPDU Aggregation and Intel Wireless Proset.
We been having issues while having the MPDU Aggregation feature turn on when using the Intel Wireless Chipset 5100 on a Dell Latitude e6400
We tested this with Jperf and a continuous ping , the client is able to maintain a connection for approximately 40 to 60 seconds without disruption and then it drops it for 5 to 6 seconds. But this is not a consistent behavior
And i was wondering if anybody had a solution for it.
Thank you
Vic
Intel MPDU aggregation
Do you have MPDU aggregation turned on or off on the client side or controller side? Please open a support case so that they can get into the bits and bytes of this.
