802.11 Client Device Interoperability
Issues with Intel Centrino Advance N6230
We have just got 150 Tosh laptop's with this Wireless Card in Intel Centrino Advance N6230. The laptops won't connect to our network with WPA2 enabled I thought it was a driver issue so put the latest driver on and still the same, once minute it will connect and then it wont and speeds are really slow not you would except.
We have dell laptops connect to the same AP and controller and working fine no issues.
Help please.
Luke
Re: Issues with Intel Centrino Advance N6230
Please turn on client debugging: while it is happening
config t
logging level debugging user
show log user 50
What is the encryption type? Are these 802.11n cards? Can they associate to an open network? What is the operating system?
How do you turn off the debugging afterwards is the normal no command...?
Next yes Wireless N dual band cards, drivers upto date.
Windows 7 32Bit
WPA2 AES
And they connect to ours some times and other times not, I have asked the 1st line support team to try this I have created a SSID for them to do it on. I will find out Monday.
I have tried some the laptop's and they seem to connect fine after deleting all the SSIDs from Windows Zero Config.
Windows 7 32Bit
WPA2 AES
config t
logging level warning user
Use "show logging level verbose" to see what debugging you have turned on. By default, it is warning for all categories
