802.11 Client Device Interoperability
Symbol 4131 APs and Motorola WT4000 readers
We have a trace where these APs are sending proprietary info (inside/though beacons) to the wearable barcode readers. They do maximize the power save capabilities; we are not sure if raising DTIM is enough or not if we change the APs with Aruba.
Any experience with Symbol proprietary beacons ?
Thanks, regards
Alcatel-Lucent Enterprise Italy
