Authenticate IAP management users via CPPM using generic Radius service
This article talks about authenticating IAP management users against AD using a generic Radius service on CPPM.
Environment : This works best on CPPM 6.2 version.
Below are the detailed steps.
1: Adding Aruba IAP as NAD device on CPPM.
Navigate to Configuration > Network > Devices
Click Add Device
Add the device as shown below.
The Vendor name should be selected as Aruba and COA enabled.
make sure that we configure the same Radius Shared secret on the VC as well.
2: Integrate Aruba IAP  with CPPM
Click on "Security" and fill the below details.
Navigate to System - Admin and make the below configuration.
3: Configuration of CPPM
Navigate to "Configuration » Start Here" and use the default "RADIUS Enforcement ( Generic )" service.
Add the NAD-IP-Address as the IP of your IAP.
Add the Authentication methods as "PAP" and the Authentication source can be AD or LDAP server.
As this just a generic service we can skip configuration of Roles and provide a sample allow all access.
Save and exit the configuration.
Version history
Revision #:
1 of 1
Last update:
‎07-11-2014 09:31 AM
Updated by:
Labels (1)
