Does CPPM allow configuring MTU for the management and data interfaces?
Question
Answer
Starting from Clearpass Version 6.4, we have an option to set the MTU for management and data interfaces on Clearpass Policy Manager.
This is ONLY allowed from Cli. Web UI configuration of the same is not available.
Configure MTU usage
Log into the Cli of the CPPM server as appadmin user to configure this:
[appadmin@CPPM]# configure mtu <mgmt|data> <mtu-value>
Example:
[appadmin@CPPM]# configure mtu mgmt 1499
* WARNING: Running this command might cause system     *
* to lose network connectivity and may require relogin.*
Continue? [y|Y]: y
INFO: Restarting network services
INFO: Successfully applied MTU settings
[appadmin@CPPM]#
Display MTU settings of the interface
[appadmin@CPPM]# show ip
Device Type      :   Management Port
IPv4 Address     :   10.x.x.x
Subnet Mask      :   255.255.255.224
Gateway          :   10.x.x.x
IPv6 Address     :   <not configured>
Subnet Mask      :   <not configured>
Gateway          :   <not configured>
Hardware Address :   C0:3FSmiley Very Happy5:37:1E:98
MTU              :   1499
Device Type      :   Data Port
IPv4 Address     :   <not configured>
Hardware Address :
MTU              :
          DNS Information
Primary   DNS  :   10.x.x.x
Secondary DNS  :   10.x.x.x
Tertiary  DNS  :   <not configured>
[appadmin@CPPM]#
Version history
Revision #:
2 of 2
Last update:
‎11-09-2014 12:51 AM
Labels (1)
Contributors
