How to perform management authentication of Cisco Switch against Clearpass
Introduction - Clearpass can act as a TACACS server and perform management authentication for Cisco switches by returning the privilege levels configured on the switch.
Environment - Tested with Clearpass versions 6.1.x to 6.4.4
Configuration Steps - Before we attempt to create a service, we shall proceed to create the different enforcement profiles required for different types of devices. Enforcement profile is the attributes which are sent down to the device to which a user is trying to access. These attributes would determine the level of access provided to the end user. For example, we could give a user read-only privileges to the Aruba controller while giving full admin access to another user.
To Create an enforcement profile, first navigate to Configuration > Enforcement > Profiles > Click on “Add Enforcement Profile”
From the enforcement profile wizard, select “TACACS+ Enforcement” as the Template
In the services tab, select the Privilege level to return to the switch. Next select the service which will be used to provide access. Here for Cisco switch we use the shell service to gain access to the shell:
From the Service Attributes section, select Shell as the attribute type, priv-lvl as the attribute name and enter the desired value. Here we use 15 for admin privilege and 1 for read only privileges.
In the Commands tab, select the checkbox “Enable to permit unmatched commands” if you want to allow the user to execute any commands
If you wish to specify what commands the user can execute, then uncheck the check box mentioned above and list the commands as shown below:
Now create another enforcement profile for read-only users as shown in the screen shots below. The privilege level in this case would be 1
Navigate to Configuration > Services > Click on “Add Service”
In the Services Configuration Wizard that comes up, select TACACS+ Enforcement as the Type
Select appropriate authentication sources sources (Local User Repository, Active Directory, Generic LDAP etc.)
Now under the Enforcement tab, we can either use the default enforcement policy or we can add a custom enforcement policy to leverage AD group membership:
Click on Add new Enforcement Policy
In the rules tab, we add the conditions to provide access:
And a similar one for read only access:
Now we have our set of rules which define access:
Cisco switch configuration commands for TACACS authentication:
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
Commands used for authorization against TACACS server:
aaa authorization config-commands
aaa authorization exec default group tacacs+ local if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ local if-authenticated
Commands used to enable TACACS Accounting to the TACACS server:
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
Version history
Revision #:
1 of 1
Last update:
‎04-07-2015 10:02 AM
Updated by:
Labels (1)
Contributors
Comments
shanshanlan
thank you, very useful. and it works
I am struggling to use radius as devices administration protocol.
Why not use TACACS instead? It's much more robust and was designed for management AAA.
shanshanlan
HI, thank you for your reply. I am also suggesting tacacs+ to my boss, the reason I need radius is that we have multiple venders for our network infrastructure. So for different devices, they think radius might be more compatible. and also I have already made tacacs working very well.
I am using cisco to test radius now
for the radius from access tracker, radius is accept my login request,but from cisco switch
User rejected
debug radius authenticatin , I got error :
Oct 19 10:32:54.206 EDT: RADIUS/DECODE(00000000): There is no Gen
ciscotest#eral DB. Reply server details may not be recorded
Oct 19 10:32:54.206 EDT: RADIUS(00000000): Received from id 1645/4
Oct 19 10:32:54.206 EDT: RADIUS/DECODE: parse VSA parts error
Oct 19 10:32:54.206 EDT: RADIUS/DECODE: convert VSA string; FAIL
Oct 19 10:32:54.206 EDT: RADIUS/DECODE: cisco VSA type 1; FAIL
Oct 19 10:32:54.206 EDT: RADIUS/DECODE: VSA; FAIL
Oct 19 10:32:54.206 EDT: RADIUS/DECODE: decoder; FAIL
Oct 19 10:32:54.206 EDT: RADIUS/DECODE: attribute Vendor-Specific; FAIL
Oct 19 10:32:54.206
ciscotest#EDT: RADIUS/DECODE: parse response op decode; FAIL
thank you
ccalhoun
You note that the Priv 1 authorization commands do not revert to local. Should local be included?
to:
aaa authorization commands 1 default group tacacs+ local if-authenticated
Chris
rogeliodavid
I never had to configure the Management Authentication for management access to the MAS Switches through RADIUS. So I wanted to confirm if I'm on the right track in regards to my thoughts towards configuring this.  200-150 VCE
Therefore, based on the fact that they will use RADIUS, I will have to create a Role, for example for IT. Then, an ACL that gives them access to the management VLAN (to manage the MAS switches). Next, configure the RADIUS servers and associate them with a group of servers that will be applied to the "aaa authentication mgmt" profile. Is this correct until now?
