Ports requirement for ALE to work with Airwave and Controller.
MVP
MVP
Q:
What ports are needed to be allowed for ALE deployment to work with Airwave and Wireless Lan controller?
A:
Ports used for ALE and Controller communication:
The Port used for ALE-Controller communication are:
  • UDP 8211 for (AMON/PAPI)
  • 4343 for bootstrap
Ports used for ALE and Airwave communication:
The Port used for ALE-Airwave communication is TCP pot 443 (HTTPS).
Version history
Revision #:
2 of 2
Last update:
‎11-25-2015 04:01 PM
Updated by:
Labels (1)
Contributors
