Occasional Contributor I
3G using RAP
If my device full id is 12d1:1003 Huawei E169
what do I put on id part when provisioning RAP?
1003
12d1
12d1:1003
12d11003
Joakim
E169
The parameters for this modem are:
usb_type=option (2) usb_init=AT+CGDCONT=1,'IP','internet' usb_dial=ATDT*99#
Below is a screenshot of where you put all the parameters.
Re: 3G using RAP
It doesnt seem to work, I also tried to use ID 0x12d11003
But no result, any ideas?
Modem works on my computer without any problems.
Also on RN times it worked on AP70.
- J
What params did you use for the AP70?
What parameters did you use for the AP70?
Re: 3G using RAP
If I could only remember....
- J
part
try 0x12d11003 for the device id
Re: 3G using RAP
Did that, didn't work.
Support Case
Please open a case with support, so that they can take a closer look.
Re: 3G using RAP
Thanks for your help, I had PIN verification on so it didn't work.
My mistake, it works now with your instructions.
- Joakim
