AP 105 half power
Good morning :
I have an AP 105 and i want to make it operate with less than it's total power(for example half it's power)
can any one help me ??
Thanks in advance.
Re: AP 105 half power
Go to Configuration> Wireless.> AP Configuration. Edit the Ap-group that you are concerned with.
Expand RF management and click on either the 802.11a or 802.11g radio profile. Change the EIRP to half power (12), and click on apply in the lower right hand corner. Next go to the Adaptive Radio Management Profile (ARM) for that band and change the assignment to disable. Click on apply in the lower right hand corner to commit.
Ok thank You for help.:D
