Frequent Contributor I
AP-105 power adapter
I am installing a few AP-105 in a few spots where coverage is poor. I would like to use local power. I live in North America. Do I use the AP-AC-UN or AP-AC-12V18?
Re: AP-105 power adapter
You can use the AP-AC-UN if you want to use a power brick OR, you can use the PD-3501G-AC if you want to use a midspan injector.
Colin Joseph
Aruba Customer Engineering
Aruba
AP-AC-12V18 adapter
The AP-AC-12V18 adapter is a valid alternative to AP-AC-UN. AP-AC-UN is a "wallwart" style adapter, while AP-AC-12V18 is an "inline" type. It's a matter of preference. Note that you'll need to order a separate (country specific) AC power cord with the AP-AC-12V18 model.
/Onno
