Access Points
AP 105's - how to mount inside an Enclosure Box
We need to install (8) AP 105's into Oberon 1032-00 enclosure boxes and currently due to the cables - these do NOT fit! How can we mount the Aruba AP 105's we've purchased into the customer's Oberon 1032-00 wall mount boxes? The metal plate inside does not allow the AP 105's to fit. Any suggestions??? :confused:
Re: AP 105's - how to mount inside an Enclosure Box
Did you check Oberon's site? They recommend using the AP-105-MNT mount kit. Here is the address:
http://www.oberonwireless.com/hard-lid_wall-mounted-access-point-enclosures.php#model1032
