AP 105 wifi will not work
I hooked up the console cable and here is the output.
APBoot 1.0.9.12 (build 22797)
Built: 2009-11-04 at 15:53:54
Model: AP-10x
CPU: AR7161 revision: A2
Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
DRAM: 128 MB
POST1: passed
Copy: done
Flash: 16 MB
PCI: scanning bus 0 ...
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000
Net: eth0
Radio: ar922x#0
Hit to stop autoboot: 0
Checking image @ 0xbf100000
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
ELF file is 32 bit
Loading .text @ 0x80e00000 (3287048 bytes)
Clearing .bss @ 0x81122810 (16 bytes)
Loading .data @ 0x81122820 (32 bytes)
## Starting application at 0x80e00000 ...
Uncompressing..............................
ü
Aruba Networks
ArubaOS Version 5.0.2.0 (build 24926 / label #24926)
Built by p4build@cyprus on 2010-08-05 at 15:21:46 PDT (gcc version 3.4.3)
CPU Rev: aa
71x CPU
Cache parity protection disabled
Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
Memory: 123520k/131072k available (1633k kernel code, 7464k reserved, 682k data,
2568k init, 0k highmem)
available.
detected lzma initramfs
initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=13542400
LZMA initramfs by Ming-Ching Tiew ...........................
AR7100 GPIOC major 0
wdt: registered with refresh
Enabling Watchdog
Creating 1 MTD partitions on "ar7100-nor0":
0x00000000-0x01000000 : "flash"
i2c /dev entries driver
i2c-talisker: using default base 0x18040000
AD7416 driver probing for devices on AR7100 I2C
Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
Starting Kernel DES KAT ...Completed Kernel DES KAT
Starting Kernel AES KAT ...Completed Kernel AES KAT
Domain Name: arubanetworks.com
No panic info available
Testing TPM... Passed
<4>ag7100_mod: module license 'unspecified' taints kernel.
AG7100: Length per segment 512
AG7100: Max segments per packet 4
AG7100: Max tx descriptor count 400
AG7100: Max rx descriptor count 252
AG7100: fifo cfg 3 018001ff
AG7100CHH: Mac address for unit 0
AG7100CHH: d8:c7:c8:c1:46:00
ATHRF1: Port 0, Neg Success
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
AP xml model 39, num_radios 2 (jiffies 3440)
init_asap_mod: installation:0
radio 0: band 1 ant 0 max_ssid 8
radio 1: band 0 ant 0 max_ssid 8
asap_gre_init: ADDED GRE protocol c00a2e10
setting bond0 as bridge child
setting gre0 as split child
USB not provisioned
Starting watchdog process...
Getting an IP address...
ag7100_ring_alloc Allocated 4800 at 0x87c28000
ag7100_ring_alloc Allocated 3024 at 0x87c3b000
AG7100: cfg1 0xf cfg2 0x7014
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
AG7100: unit 0: phy not up carrier 1
Writing 4
Writing 4
AG7100: unit 0 phy is up...RGMii 100Mbps full duplex
AG7100: pll reg 0x18050010: 0x1099 AG7100: cfg_1: 0x1ff0000
AG7100: cfg_2: 0x3ff
AG7100: cfg_3: 0x18001ff
AG7100: cfg_4: 0xffff
AG7100: cfg_5: 0x7ffef
AG7100: done cfg2 0x7115 ifctl 0x10000 miictrl 0x12
10.30.8.206 255.255.0.0 10.30.0.2
Running ADP...Done. Master is 10.30.0.29
ath_hal: 0.9.17.1 (AR5416, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Right
s Reserved
ath_rate_atheros: Aruba Networks Rate Control Algorithm
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserve
d
ath_pci: 0.9.4.5 (Atheros/multi-bss)
ath_dev_attach: unable to attach hardware; HAL status 3
shutting down watchdog process (nanny will restart it)...
<<<<< Welcome to the Access Point >>>>>
Is this a bad piece of hardware or does it just need a software update? It receives an IP and is pointing to the IP of the controller.
Retired Employee
Re: AP 105 wifi will not work
Seth,
We would need some more information in order to figure out what is going on here.
1. What is the code version of the controller?
2. Is this AP105 being provisioned as a Remote AP or a Campus AP?
3. Is CPSEC enabled on the controller?
4. Do you see this AP in the "show ap database" output? If yes, then please post the output.
HT
3600 controller with 5.0.2.0
campus
Disabled
AP Database
Name Group AP Type IP Address Status Flags Switch IP
d8:c7:c8:c1:46:00 default 105 10.30.8.206 Down 10.30.0.29
campus
Disabled
AP Database
Please open a TAC case so you can get it RMA'd. It looks like a hardware issue based on that "unable to attach hardware" message.
Retired Employee
Please post the following output
show ap-group default
---- Check the name of the AP system-profile under the group information
show ap system profile
I would like to check if the system profile has an LMS IP set which points to a different controller.
Also, when you reboot the AP, do you see it coming up on this controller for couple of minutes and then going down again?
Please execute the following steps to get more information
1. reboot the AP
2. Check the IP address of the AP
3. On the controller run the following command every 10-15 seconds to check the traffic sent and received from the AP
show datapath session table | include
Hardik
HT
(Aruba3600-US) #show ap system-profile default
AP system profile "default"
Parameter Value
LMS IP N/A
Backup LMS IP N/A
LMS Preemption Disabled
LMS Hold-down Period 600 sec
Number of IPSEC retries 360
LED operating mode (AP-9x/AP-10x/AP-12x/AP-18x/RAP-5x only) normal
RF Band g
Double Encrypt Disabled
Native VLAN ID 1
SAP MTU N/A
Bootstrap threshold 8
Request Retry Interval 10 sec
Maximum Request Retries 10
Keepalive Interval 60 sec
Dump Server N/A
Telnet Disabled
SNMP sysContact N/A
AeroScout RTLS Server N/A
RTLS Server configuration N/ARemote-AP DHCP Server VLAN N/A
Remote-AP DHCP Server Id 192.168.11.1
Remote-AP DHCP Default Router 192.168.11.1
Remote-AP DHCP DNS Server N/A
Remote-AP DHCP Pool Start 192.168.11.2
Remote-AP DHCP Pool End 192.168.11.254
Remote-AP DHCP Pool Netmask 255.255.255.0
Remote-AP DHCP Lease Time 0 days
Remote-AP Backup Ports Enabled
Remote-AP uplink total bandwidth 0 kbps
Remote-AP bw reservation 1 N/A
Remote-AP bw reservation 2 N/A
Remote-AP bw reservation 3 N/A
Heartbeat DSCP 0
Session ACL ap-uplink-acl
Corporate DNS Domain N/A
Maintenance Mode Disabled
WISPr Location-ID ISO Country Code N/A
WISPr Location-ID E.164 Country Code N/A
WISPr Location-ID E.164 Area Code N/A
WISPr Location-ID SSID/Zone N/A
WISPr Operator Name N/A
WISPr Location Name N/A
Remote-AP Local Network Access Disabled
Not that I can tell. It powers up, runs through the boot cycle and then sits there with only ENET and PWR lights blinking.
1. reboot the AP
The IP is 10.30.8.206.
Here's the output from running the command on #3.
(Aruba3600-US) # show datapath session table | include 10.30.8.206
10.30.8.206 10.30.0.29 17 49152 514 0/0 0 0 0 1/0 2 FC
10.30.0.29 10.30.8.206 17 514 49152 0/0 0 0 0 1/0 2 FY
10.30.8.206 10.30.0.29 17 49152 514 0/0 0 0 1 1/0 c FC
10.30.0.29 10.30.8.206 17 514 49152 0/0 0 0 0 1/0 c FY
10.30.8.206 10.30.0.29 17 49152 514 0/0 0 0 1 1/0 1b FC
10.30.0.29 10.30.8.206 17 514 49152 0/0 0 0 1 1/0 1b FY
10.30.8.206 255.255.255.255 17 49152 8200 0/0 0 0 0 1/0 8 FC
255.255.255.255 10.30.8.206 17 8200 49152 0/0 0 0 0 1/0 8 FY
10.30.8.206 10.30.0.29 17 49152 514 0/0 0 0 0 1/0 4 FC
10.30.0.29 10.30.8.206 17 514 49152 0/0 0 0 0 1/0 4 FY
10.30.8.206 239.0.82.11 17 49152 8200 0/0 0 0 1 1/0 9 FC
10.30.8.206 10.30.0.29 17 8211 8211 0/0 0 0 1 1/0 7 FC
10.30.0.29 10.30.8.206 17 8211 8211 0/0 0 0 1 1/0 7 FY
Retired Employee
We do see the datapath session from the AP IP address, so it may not be a hardware issue. From the session table, it looks like the controller is not able to reach the AP IP address. Can you try to ping AP105 IP address from the controller?
Hardik
HT
The lines:
00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000 Net: eth0 Radio: ar922x#0
should have two radios, but only one is recognized. Rma.
The "hardware issue" is NOT that it is unable to connect to the controller. It is that it is not recognizing one of its radios that it needs to transmit with.
