AP-125 Bootup Issue
I am facing issue with AP-125 not able to bootup via PoE. here is the log which i retrieved from console :
APBoot (build 20343)
Built: 2008-12-27 at 17:03:46
Model: AP-12x
CPU: OCTEON CN50XX-SCP revision: 1
Clock: 500 MHz, DDR clock: 333 MHz (666 Mhz data rate)
Power: POE
POST1: passed
POST2: mem 3 (Mismatch at 80100000: Expected 80ef00ff got 80ef00fd) FAILED!
### ERROR ### Please RESET the board ###
Have any one of you encountered this issue before?
Contact Support
This access point probably needs to be replaced.
Colin Joseph
Aruba Customer Engineering
Re: AP-125 Bootup Issue
Hmm, thanks for the feedback.
I have already opened ticket with Aruba TAC Support, lets c what they come up with :)
