AP 125 Installation Guide
Does anyone have a link to the AP 125 Installation Guide?
In particular, I am looking for an LED Status chart like the AP 65 Installation Guide has that lists all of the LEDs, Colors, Activity, and Action.
If you have a support login, go to
https://www.arubanetworks.com/support, then click on Documentation >
Hardware > AP Installation Guides > AP-120 Series > AP-120 Series Indoor
Access Point Installation Guide.
Or, you can click on the following:
https://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/C
ommand/Core_Download/Default.aspx?EntryId=1670
If you don't have a support login, you will need to get one and then go
that site.
Re: AP 125 Installation Guide
Excellent, thank you.
Why the search engine on the site couldn't find it, I don't know but that was just what I needed.
Frequent Contributor I
Hello, the LED Meanings are:
PWR:
Green Steady Power on device ready
Green flashing System initializing
ENET 0:
Green/Amber off No link
Green on 1000 Mbps link
Amber on 10/100 Mbps link
ENET 1:
Green/Amber off No Link
Green/amber blinking Data activity
11A/N:
Amber on Wireless link is legacy 11a.
Green on Wireless link is 11n 5Ghz band.
11B/G/N:
Amber Wireless link is legacy 11b or 11g.
Green Wireless link is 11n 2.4Ghz band.
Best Regards
