AP Power Problem
Ever since updating to os version 6.1.1, I have random AP-105's that the power is increased and decreased repeatedly in some cases every 15 minutes or so. In some cases there have been reports of clients being dropped at the time of the adjustment. We are using the default ARM profile. Any ideas on what could be wrong or has anyone else seen this.
thanks
Ryan
Re: AP Power Problem
If this is critical, you should open a case with support (support@arubanetworks.com), so they can gather all your information and find out what the cause is.
OK Thanks.
