Access Points
AP latency to remote controller
Is there a Aruba document that shows the maximum latency for a Aruba 135 and 105 deployed at a remote site with no local controller connecting to a 7200 series controller over the WAN?
Or a Aruba document that has best practices outlined for a regional deployment?
Re: AP latency to remote controller
You can read this doc doesn't specifically talks about the 135/105 to 7200 connection from a remote location but addresses some of your questions in regards best practices for remote locations
http://www.arubanetworks.com/wp-content/uploads/RAPVRD_version_8.pdf
How do you have the VAP configured ? Tunnel / split tunnel ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Read this document about deploying APs over slow links:  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=188
Thank You
