AP power
Is there a way to override Arm and up the power on an Ap?
Re: AP power
Yes. Set the min-tx-power setting in the ARM profile you're using. This basically says.."ARM, do what you want, but don't set power below X value."
I use it frequently....
Re: AP power
Thanks. I'll give it a try
