Access Points
AP sending "too large" frames
Hi! I have an AP connected to a Cisco 2950. Users connected to that AP claims that they are being disconnected from the Wireless Network many times during the day.
I checked the the port in which the AP is connected and I see that there is a slow increase of "input errors".
When I check the switch ethernet-controller for that port it show that there is also a slow increase of "Invalid frames, too large". I also get "0 giants" frames and no CRC/FCS errors.
I know that the Wireless frames are 2346 bytes by default and that the Ethernet MTU size is normally 1500 bytes. Does this has anything to do with the errors?
Any ideas on how to tweak the AP so it only send 1500 bytes frames or smaller?
Thanks!
"too large" frames and input errors on the controller
Im curious if there was a fix for this? I have a customer who has input errors on the controller interfaces (in Japan) but no errors on the switch side. We have tried several things (different ports, different cables, hard setting both sides) but continue to get these errors.
Any thoughts?
Ck
AP System Profile
Thanks!
In the AP System Profile, there is a MTU parameter. change that to 1500.
Contributor I
Re: AP sending "too large" frames
Is that the SAP MTU field?
Sap mtu
Yes.
Hi, I have the same problem 'input errors' on the aruba 3200 controller and no errors on the nortel bes-1020 poe switch.
jason
Not the same
This is not the same thing. In this case, the giants or "errors" should be showing up on the Nortel switch instead. Errors on the Aruba controller means that the Nortel switch is passing frames that the Aruba controller cannot understand, in general. It is not the same as this thread.
mat
Occasional Contributor I
I'm also having the same issue with the MTU size he HP switches my ap's are plugged into have "Too Many Undersized/Giant Packets on port #" i looked at my system profile and SAP MTU is blank.
what is the default setting for this if left blank?
Try 1500
There is no default value. It uses MTU discovery, which is why you get the Giant packet errors. You should change it to 1500 or lower to make those errors go away.
I was refering to the second post. In which the 'controller' was having the input errors.
