Access Points
AP93 Clients keep roaming even if not needed or not when needed
I would like to receive from u guys here some tips regarding some issue I have
I have a site with 8 units of AP93 per floor (ArubaOS 6.0.1.3),
The issue is:
Clients keep staying connected to far units or the wrong AP…far unit not in LOS , even due I disable the 1,2,5 mbps and I put the ARM in 20-20EIRP… or sometime users keep roaming a lot from ap93 unit to other ap93 unit , even due the client is standing and not moving – I checked the client driver it's seems to be very updated.
Is there any things I can change in the ARM settings to give better throughput experience ( less "jumping felling" roaming \or roaming only when needed) to the client with less roaming between units when not needed and good roaming when really needed? :confused:
thanks in advance for all the helpers.. waiting to hear some good tips & idea :D
Re: AP93 Clients keep roaming even if not needed or not when needed
You can try the "Local Probe Request Threshold" parameter under Advanced in the SSID profile. A good starting number is 20. Go to Configuration> Wireless> AP Configuration. Edit your AP-Group with your access points in it. Expand Wireless LAN, Expand Virtual AP and Expand SSID profile. Click on the SSID profile you are interested in. Click on the Advanced Tab and go down to Local Probe Request Threshold (dB) box and enter 20 to start with.
"The SNR threshold below which incoming probe requests will get ignored". Incoming client requests on that access point to join will be ignored under that threshold. If you use this, please do not combine it with any other methods to improve roaming so that you know how effective it is. A zero in this field turns it off.
On the commandline:
(3600) config t
(3600) (config) #wlan ssid-profile aruba-hotel
(3600) (SSID Profile "aruba-hotel") #local-probe-req-thresh ?
requests will get ignored (only used if
local-probe-response is also enabled)
thanks - i will check the tip u wrote and update if it's helped
:cool:
still didnt solved the issue ..
any more ideas?
I would open a support case., then. Someone needs to go over the details of your case with you to find out what the problem is.
