Access Points
AP93 signal dramatically swing
Hi all,
Could you please give me some idea how to troubleshoot on the problem I’ve found on the Aruba wireless.
I’m sitting in front of AP93, about 2m far, but the signal is dramatically swinging. Please see the attached graph for more detail.
My connection is unstable. Please suggest how could i fix the problem.
Best regards,
PS> The controller is 620
Re: AP93 signal dramatically swing
Do you have a BT device or a device that works on 802.11b/g nearby?:confused:
I had a similar problem and at the end was a presential detector.
Good luck.
Hi all,
Best regards,
What version of code is this and what controller? Also, what client are you using to measure the signal?
