Access Points
Ap's not talking to controller
hi,
i have 34 AP's on a 3600 controller all spread over 4 POE switches and all 4 ports on the controller channelled togther on 1 Vlan
i seam to be getting a random probley where some ap's (not allways the same ones) do not find the controller for a very long time (2 hrs ) or atall
all ap's are on DHCP and there is a DNS lookup to aruba -master
the odd thing is that some of the ap's that are not finding the controller oare on the same POE switch as working ones
any thoughts
thanks colin
Re: Ap's not talking to controller
i forgot to say that all this is currentley in a tempory building and power is shutdown every night
When do these APs have this problem, during startup? Are these enterprise POE switches? Is it possible that they are oversubscribed when they start up? There are a number of variables in here.
The big question is, when did these problems start? Did it ever work? What change was made that coincided with the problems?
the problem dose seam to happen during startup if i power cycle the ap later in all workes
the problem has been there since day 1
the switches are HP procurve 2620-poe thay are getting replaced for the 1 gig modle but thay have plenty of power in them as the ap's are balanced accross the 3 of them
You should plug into the console of the access points that do not work to see what they are doing. If you need immediate assistance with this, you should open a support case, because on the forum, we are dealing with limited information due to privacy concerns...
