Access Points
Ap92 with external antenna
Any recommend antenna for AP92? I'm looking for omi-directional antenna run on single band or dual band. The propose AP will support terminal like notebook and smart phone.
Ap93
The AP93 has a built-in omni directional antenna. Why don't you try that instead?
Re: Ap92 with external antenna
there is some reason why we need a detectable type antenna
Reason for the antenna
The reason why you have an external antenna will determine what TYPE of antenna you get.
