Access Points
Frequent Contributor I
Can IAP 105 and IAP 93 work together Amigopod
Hi All,
Can IAP 105 and IAP 93 work together with Amigopod? In term of redirect the captive portal to Amigopod for user authentication and advertising.
Please advise.
Thanks.
Re: Can IAP 105 and IAP 93 work together Amigopod
You can certainly do that. The main requirement is that your users be able to route to the ip address of the Amigopod server to see the Captive Portal page. In instant, you create a new guest network with a Splash page that is external and point to the IP and URL of the Amigopod page that you created. The page will then display any content you desire.
