Access Points
Can a Cisco 1200 ap work with Aruba 3600 Controller?
We have a Cisco 1200 ap that we are needing to run off of our Aruba 3600 controller. Is that possible???
Re: Can a Cisco 1200 ap work with Aruba 3600 Controller?
No..not possible from the controller controlling the Cisco AP from a thin AP point of view. You COULD run that 1200 in autonomous mode and have the Aruba controller in the datapath between that AP and your network and do role-based access control though...
