Contributor I
Heat Map for AP105
Looking at my coverage heat map I see a parobolic coverage instead of the uniform coverate I expected for the AP105's that I have deployed. (see attached attachment).
Why? I thought the AP105 had a omni antenna...
Aruba
AP-105 antenna pattern
Confirming that the AP-105 antenna pattern is omni-directional. This seems to be a problem with the planning tool.
/Onno
Contributor I
Re: Heat Map for AP105
Thanks I will turn in a support ticket.
Contributor I
Its a Bug
Was told by tech support that this is a bug that will be fixed in the next release
