Access Points
OHD
Contributor I
Help: How to configure ap 105 from WLAN mode (Amber Light) to 11n mode (Green Light)
How to configure ap 105 from WLAN mode (Amber Light) to 11n mode (Green Light). anyone ??
Previously, both 11A/N & 11B/G/N it was Green light but now it was Amber (red)..
I not sure what happen... :(
Re: Help: How to configure ap 105 from WLAN mode (Amber Light) to 11n mode (Green Light)
If you have the SSID profile configured with "Open", "WPA-AES" or "WPA2-AES" the radio will appear green for 802.11n or HT. Any other encryption type will make it non-HT or amber.
OHD
Contributor I
Hi Cjoseph..
Thanks.. I will check it out...
