Access Points
Contributor I
How to reset AP61. Not by console
I have some AP-61 configured by another person. I am trying to configure them in my A200, but it does not appear. I think they have an specific enviroment, but I cannot reset it, because when I connect them to the console no text appears in the the display. I have tried with differents speeds 9600, 2400, ... but got nothing. Is there another way to reset them? I have read that some APs have a button inside to reset the device.
The leds seem to blind correctly, so I think they work properly.
Re: How to reset AP61. Not by console
You need a special console cable to reset the AP61. Please see the post here:
Colin Joseph
Aruba Customer Engineering
