Access Points
I can't revert IAP105 after provisioning to thin ap
I convert the IAP105 to thin ap for testing with the controller 650 it is successful
then I want to revert but it isn't successful i reset button and see error as below
Re: I can't revert IAP105 after provisioning to thin ap
Please use the reset instructions from the user guide:
The reset button can be used to return the AP to factory default settings.. To reset the AP:
1. Power off the AP.
2. Press and hold the reset button using a small, narrow object, such as a paperclip.
3. Power-on the AP without releasing the reset button. The power LED will flash within 5 seconds.
4. Release the reset button.
The power LED will flash again within 15 seconds indicating that the reset is completed. The AP will now continue to boot with the factory default settings.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
