IAP-93 and Noise
I have 10 IAP-93. All IAP show the big noise in the web-interface even if there are no neighbors around. And I have a IAP-105 which doesn't show noise presence and works with greater speed.
Why noise is visible? How to raise speed?
Screenshots with IAPs which work in one room:
Re: IAP-93 and Noise
That means in the area, there could be non-802.11 interference like wireless video, bluetooth, etc. It is not necessarily wifi. -65 is pretty bad... Look around and see if you see any of those devices.....
Does the AP-93 show high noise always or for few seconds?
Can you also post the screen shot of access-points page?
I just want to see the channels Aps are working in.
Hi, i'm colleague of Maxim.
He's busy today.
Noise shows always.
Client connects on channel 13 (ARM enabled), type GN.
Max speed - 65 mbps.
When I connect other Instant, IDS shows that both IAP works on HT20MZ
(atilla_com_ua_ap01 on screenshot).
How can i make them works on HT40MZ ?
I see next info in console IAP-93:
d8:c7:c8:c4:1d:ae# sh ap mesh link
Module MESH is busy. Please try later.
d8:c7:c8:c4:1d:ae#
d8:c7:c8:c4:1d:ae#
d8:c7:c8:c4:1d:ae# sh ap mesh counters
d8:c7:c8:c4:1d:ae#
d8:c7:c8:c4:1d:ae#
d8:c7:c8:c4:1d:ae# sh ap mesh neighbours
