Access Points
Occasional Contributor I
Is there any bandwidth limitation for bridge mode?
I need to connect to switches via APs. And if i use AP125 can i get 300Mbps or the highest throughput with bridge mode? Or is there any bandwidth limitation for bridge mode. Do you know what is the exact practical BW value is supported in bridge mode?
Re: Is there any bandwidth limitation for bridge mode?
There is no BW limitation in bridge mode, unless you are using encryption... Depending on the encryption you use in your VAPs, 11n AP throughput may be less than the maximum throughput it can achieve... As you know, you'll be encrypting and decrypting traffic at the AP if you use bridge mode and the AP12x and AP13x devices have the hw crypto engine on the AP itself.
