Occasional Contributor I
Limiting Users Per AP
I have this particular setup that have a requirement to limit the amount of Users to max 20 per AP.
I do know that Aruba is able to auto balance if too many users connect to a particular AP. However, is there anyway that i could configure or set to ensure that each AP can only take up to 20 users?
Thanks for the help in advance!
Cheers!
Re: Limiting Users Per AP
You can do this in the SSID profile:
(awl-800) (config) #wlan ssid-profile awl-test
(awl-800) (SSID Profile "awl-test") #max-clients ?
Max Wireless CLients for AP. Range: 0-255. Default:
64.
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
Thanks alot! it helps!
Large Conference Room
Has anyone ever done this in large conference rooms with multiple APs? Also, I take it this setting is for the whole AP and not per radio?
