Mesh Issue
Could i make mesh by Ap-60 and Ap-120 ?and how ?
Re: Mesh Issue
You set them up the same way that you would provision any other Mesh AP. When you provision them, it will ask you for the db gain of the antennas that you put on the access points.
Re: Mesh Issue
Do you already have Mesh Nodes setup or are these devices going to be Mesh Nodes?
