Access Points
Super Contributor II
Multiple IAP Cluster on same LAN
Does anybody know if it is possible to run multiple Instant AP Clusters on the same LAN segment with separate SSID's?
I had a requirement during a conference to isolate an SSID to only one room and 1 AP and i attempted to do this by disabling Auto-Join on the IAP controller and then resetting another IAP to see if it would come up.
Each time i reset the separate IAP, it got to the master discovery stage and it hung.
I guess what i was trying to achieve was similar to AP groups on a controller however this didn't seem to work for me and i ended up having to deploy a standalong 620 controller in the room.
Scott
Re: Multiple IAP Cluster on same LAN
That is not supported, so I would not expect that to work.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
i suspected that might be the case!
thanks
Scott
