Power consume for AP85TX
Hi All,
I would like to know about consume power of AP85TX (Max watt) if it use with POE(IEEE802.3at about 50 watt), Is it limit consume power at 15.4 watt (IEEE802.3af) or more than that ? and How many to maximum consume power on AP85TX in watt unit ?
Re: Power consume for AP85TX
The AP-85's consumption shouldn't exceed 15.4W, so long as the cable lengths are within spec. The AP-85 is an 802.11af-spec device.
Jerrod Howard
