Access Points
Frequent Contributor I
Remote AP - Standard Mode/Split Tunnel
How do I obtain a local IP for a remote AP? I have a branch office with remote AP's, the controller is not local (off site datacenter)..DHCP is local, file servers local, etc.. How can I obtain a local address (VLAN)? Can't use Bridge mode because we use captive portal. Any ideas?
Re: Remote AP - Standard Mode/Split Tunnel
The questions are:
- What kind of wireless network is it (guest, employee, etc)?
- Does it use encryption/authentication?
- What services are you trying to deliver to the client?
Employee and Guest access
Encryption: TKIP
Authenication: 802.1x using Radius, Captive Portal for Guest Access
Services?
What you can do is:
- On Employee, change the Virtual AP forwarding mode to bridged. That will give the clients an ip address in the same local range as the access point.
- On the Guest SSID, you can make it fully tunneled so that you can filter guest user traffic back at the headend.
How does it get assigned a VLAN though? loop back address?
It would get the ip address from whatever the local subnet DHCP server is providing. User traffic is truly bridged through the ethernet of the access point.
Remember!
since u have mentioned captive portal when u were asked what type of authentication u wud like to do......here is a quick note
Captive portal doesnt work in bridge mode....
