Access Points
Remote APs disappearing after OS Upgrade
Good afternoon. We recently upgraded our Aruba OS from to Since then some of our Remote APs have disappeared. I have tried reseting them back to factory defaults and re-provisioning them without any luck. I am able to ping them but they won't show up in the controller. Any thoughts or suggestions? Thanks.
Make sure you don't have an LMS-IP or a Backup LMS-IP in the AP system profile of the ap-group that your RAPs are in.
Colin Joseph
Aruba Customer Engineering
