Access Points
Contributor I
ap 105 are not giving a/n and b/g signal
This is the 1st time i encounter this issue in my place, where as at least 2 of my ap 105 is not giving a/n and b/g signal. It is because the their light is not blinking. The temporary solution that i applied is restart the controller and it seem to resolve it. However i would like to know what had happen. How shall i go about that? By the way, i had recently upgrade to OS 6.0.1
Re: ap 105 are not giving a/n and b/g signal
If it is always happening, we can try to help you here, because it is probably a configuration issue. If it is happening once awhile, you should open a support case, because they need more information to track down your specific issue.
