Access Points
Regular Contributor II
ap-125 client connection issue
Yesterday, we had an unexpected power outage. Now I have a few APs that will not allow some clients to connect. I reboot the AP and the clients can connect fine. Any ideas?
Status of AP ?
Did you check the log files and/or the 'show ap database' output when the AP was in the state you describe ?
Both would be / would have been useful to determine the state the AP was in. Troubleshooting after the fact will be largely speculation.
Re: ap-125 client connection issue
I was in the Web console. The APs in question were all up and some had 2 - 3 clients on it. But after a reoot of the AP the clients connected fine. I running Aruba OS I was thinking about swapping the APs out to see if that would help.
