Access Points
how many simultaneous voice calls can be carried by a single AP105
Can anyone tell me, How many individual voice calls can be simultaneous carried by an AP105 Access point at any given time on the 2.4Ghz band, and then at 5Ghz.
I know clients will roam etc, but what is the breaking point before calls will be impacted.? does anyone know? this is for planning purposes.
Factors
There are a few factors that will determine that. Band, Codec, phone type, will there be any data clients in the mix, etc.
For budgeting purposes, a number of 8 is safe.
