Access Points
Occasional Contributor I
reset ap105 without console cable
Anyone know how to find and reset a ap105 without using a console cable?
Say something messed up, a user put in the wrong information when provisioning or the device is going crazy and it will connect to the master. The device is seen on the switch. You want to reset the device to defaults so it does dhcp and can connect to the master.
Is there a tool or a api kit available to do such a thing? It would be nice to be able to reset via mac address.
Re: reset ap105 without console cable
The console cable is the only way :(
Colin Joseph
Aruba Customer Engineering
Contributor II
i have the tipical cisco blue console cable, it works with the AP-105?
Yes :)
ACMP 6.4 / ACMX #107 / ACCP 6.5
