Do MAS switch supports all OSPF area types as controller ?
Environment         Typical OSPF area environment integration using MAS switch.
This article applied from MAS switch code 7.2 and above.
Yes; MAS switch supports all OSPF area types as controller.
  1. NSSA
  2. Totally Stubby
  3. Totally NSSA
Configuration CLI
(ArubaS3500-48P) (config) #router ospf
(ArubaS3500-48P) (Global OSPF profile) #area 1 ?
nssa                    Set an area as NSSA area
stub                    Set an area as stub area
<cr>
(ArubaS3500-48P) (Global OSPF profile) #area 1 stub ?
no-summary              Do not send summary LSA into this area
<cr>
(ArubaS3500-48P) (Global OSPF profile) #area 1 stub no-summary
(ArubaS3500-48P) (Global OSPF profile) #area 2 nssa ?
default-info-originate  Enable sending of default route in this NSSA
translate-always        Translate Type-7 to Type-5 lsa
<cr>
Default route can be advertised to various areas. To send default route in NSSA, following configuration can be used:
ArubaS3500-48P)(Global OSPF profile) #area <areaid> nssa default-info-originate metric <1-65535> metric-type <1-2>
To send default route in normal area, following configuration can be used:
(ArubaS3500-48P)(Global OSPF profile) #default-info-originate [always]
Version history
Revision #:
1 of 1
Last update:
‎11-11-2014 05:17 PM
Updated by:
Contributors
