How do I identify the mesh between Aruba AirMesh series routers?
Question
Answer
Product and Software: This article applies to all ArubaOS and MeshOS versions that run on MSR2000, MSR4000, MST200, and MSR1200.
Use a mesh ID to identify the mesh. Mesh IDs are used to limit the mesh network scope. For performance reasons, one mesh network should contain less than 50 devices.
If AirMesh devices are used to build WDS links, they should be configured with a same mesh ID.
Version history
Revision #:
1 of 1
Last update:
‎06-03-2014 04:57 PM
Updated by:
Labels (1)
Contributors
