How to Check Logs on MSR?
MVP
MVP
Q:
A:
There is no option to view logs directly on the MSR unlike Controller or IAP.
However, we need to configure syslog server and view the logs on the Syslog Server
In order to enable Syslog on MSR, we can use the below command:-
 Syntax : logging <server-ip>
Example : logging 10.17.170.111
Version history
Revision #:
2 of 2
Last update:
‎04-23-2017 12:20 AM
Updated by:
Labels (1)
Contributors
