Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Aruba Documentation Portal
Aruba Support Knowledge Base
Community Learning
News
ACEX Hall of Fame
MVP Overview
Tech Corners
Search
View Entry
AirMesh
Community Home
Discussion
2
Library
23
Members
10
last person joined: one year ago
Articles on AirMesh products
Back to Library
How to configure Mesh to improve VoIP performance?
0
Kudos
Jul 01, 2014 05:23 PM
Arunkumar
1) The mesh-point should be evenly distributed between the numbers of portals.
Each portal should have its own ap-group. This will allow us to assign a primary cluster and radio profile per group.
2) Why should we assign a primary cluster per ap-group?
If all the portals and end-points are in the same group, the end-points will not be load balance between the portals, when they are all on the same channel.
3) Why should we create a different mesh-radio-profile per ap-group? If all the portals are on the same channel, there will be contention in the air. If we have four end-points, it will be better for the mesh-point to be on two different channels.
4) There is an advantage of assigning a mesh-channel.
a) The network will not need to scan and converge.
b) We can avoid DFS channels.
c) We can prevent two portals to be on the same channel.
d) The approach will evenly distribute channels.
5) If we assign channels, will we break the redundancy?
No, we can still configure multiple cluster-profiles with a different priority because the endpoint will scan the valid channels, if there is second mesh-cluster configured.
Please review the following simple example:
(BRANCH2400) #show ap-group voice-1
AP group "voice-1"
Parameter Value
Virtual AP voice
802.11a radio profile default
802.11g radio profile default
Wired AP profile default
Ethernet interface 0 link profile default
Ethernet interface 1 link profile default
AP system profile default
VoIP Call Admission Control profile default
802.11a Traffic Management profile N/A
802.11g Traffic Management profile N/A
Regulatory Domain profile default
SNMP profile default
RF Optimization profile default
RF Event Thresholds profile default
IDS profile ids-low-setting
Mesh Radio profile channel44
Mesh Cluster profile cluster-a priority 1
Mesh Cluster profile cluster-b priority 16
(BRANCH2400) #
(BRANCH2400) #
(BRANCH2400) #
(BRANCH2400) #
(BRANCH2400) #show ap-group voice-2
AP group "voice-2"
Parameter Value
Virtual AP voice
Mesh Radio profile channel48
Mesh Cluster profile cluster-a priority 16
In the above example, we have two different ap-groups. Each ap-group is assigned a mesh-radio-profile. If the primary portal should fail, the endpoint will move to the secondary cluster.
How should you troubleshoot VoIP on a mesh network?
In a Mesh environment, the chain could be one portal with two end-points. The topology could look like this: portal1-----end-point1-------end-point2. In this example, we would verify the voice performance on portal1 and then end-point1 and then end-point2. Please keep in mind that each hop will add delay. The voice quality can be explained by added delay of the hops..
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2024 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
