AP OPerating system
Good evening for all:
How Can I downverse OS version in Aruba AP for example it takes OS ver 6 image from controller and i want it to be returned to OS 5.0.2 again
Thanks in advance
Re: AP OPerating system
The access point gets its code from the controller. If you upgrade the controller, it will upgrade or downgrade the access points to match.
Colin Joseph
Aruba Customer Engineering
Thank you I try it now you are right
