Contributor I
AP load balancing
We're concerned that some of our APs are getting overworked by too many clients attached.
We're using MMS as a report engine only.
If we set a ceiling on how many clients may connect per ap, how will the APs decide which clients to allow?
Is it a smart decision (based on signal quality) or does it just deny above the limit?
We'd like to spread the clients out, but we don't want to create a situation where users are getting rejected.
Can Anyone tell what they are doing to load balance clients on APs?
